ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Terry, I agree here.....If someone has snow and is riding trails (not off-trail), I would like to hear how 1-3 with the orange spring works out.
I hope someone checks backpressure with 3/2 and 3/1 and compares that to backpressure with stocker at 3/3.
It seems like something might be diff with tangs or the spring just simply has way way more torsional pressure.
I like the idea of more sidepressure with "similar" torsional pressure to stock for good overall performance.
Dan
aquaticlaker
- Feb 21, 2009
- Green Lake WI
- SIDEWINDER L‑TX LE 50TH
- Green Lake Wi
updated
Just shooting all a note on the orange secondary spring.
I have not blown a belt but I don’t run as hard as some people. I was wrapped at 3 3
I changed to 2 3 and I am up north now trying it.
I have 1000 miles on overall and was getting what seemed to be a lot of belt dust.
I am running TP clutching wit TD flash. Powertrail with CAI and TD muffler
Stock helix
Just made two lake runs and I am hitting the rev limiter at 9500.
The clutch setup for weight is what Lon told me to start with. Here is the data on my first setup.
Heal 3/4 set screw
Middle 3/8 hex head screw
Tip 7/16 hex head with 1 thick washer
Made changes as follows
Heal 3/4 set screw
Tip 7/16 hex head with 2 thick washers
Made couple runs and did not hit rev limiter. WOT rpms were at 9000
I made one final change but was unable to try it yet.
Heal 3/4 set screw
Middle 3/8 hex head screw with 2 thin washers
Hope to try this weekend.
1500 mile on original belt. I did notice less belt dust this weekend. Today I cleaned clutches in order to get a feel for how much dust is coming off.
Also adjusted the belt height
Made the last change after talking to nos-pro. Thanks
Mike
Stock helix
Heal 3/4 set screw
Heal 3/4 set screw
Heal 3/4 set screw
Mike
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
What helix?updated
Heal 3/4 set screw
Heal 3/4 set screw
Heal 3/4 set screw
Mike
aquaticlaker
- Feb 21, 2009
- Green Lake WI
- Green Lake Wi
StockWhat helix?
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
updated
Stock helix
Heal 3/4 set screw
Heal 3/4 set screw
Heal 3/4 set screw
Mike
Your tuning with what is probably a worn out belt. If you put a new belt on and break it in properly I bet your rpm’s will drop down.
aquaticlaker
- Feb 21, 2009
- Green Lake WI
- Green Lake Wi
Good point. Will change that also.Your tuning with what is probably a worn out belt. If you put a new belt on and break it in properly I bet your rpm’s will drop down.
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
- 2017 Sidewinder BTX LE
2012 Nytro XTX 1.75
Shhhhhhh...its a secret!
That’s what I’m beginning to think!
- Apr 14, 2003
- Hessel, Michigan
Just received a pm from a member here and he tried 3-0 twist and had cool clutches, went 123mph gps with 8JP on a snow covered river....whereas the 2-3 twist, the clutches were a lot warmer and mph slowed to 117mph gps with both the 8JP and 8DN.
This is good because we still have room to play with percentage twisting.
aquaticlaker
- Feb 21, 2009
- Green Lake WI
- Green Lake Wi
Was this with TP clutching?Just received a pm from a member here and he tried 3-0 twist and had cool clutches, went 123mph gps with 8JP on a snow covered river....whereas the 2-3 twist, the clutches were a lot warmer and mph slowed to 117mph gps with both the 8JP and 8DN.
- Apr 14, 2003
- Hessel, Michigan
Yes, it was Thunder Products clutching.
Also running the 911 cover, 35/39 helix, cold air intake and powertrail
dem1000
- Feb 15, 2016
- Jokkmokk
- Sweden
- Side Winder MTX 153 -20
m8000 153 -19
Side Winder BTX 153 LE -17
M6000 153 -17
SR Viper MTX 153 -16 sold
Apex XTX -14 sold
Nytro XTX -11 sold
What do you say about removing weight in the heel when turning the secondary less?
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
2014 SR Viper XTX SE (Sold)
Keep your weight in the heel. It keeps the belt from slipping at engagement.
Snowaddict
- Feb 28, 2005
- Menasha, WI
- '17 Sidewinder LTX-LE
- mstahl88
I'm confused. I thought the more wrap, the higher the RPM? (Theoretically better speed as well? ) Especially curious as I just first tried mine at 2-3. Definitely warmer clutches than with stock (secondary spring) . Outside temp was 45 degrees though and no top end runs.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Yes more rpm with more twist. The caveat is too much twist and the clutches may stop shifting out. The big deal here is hot clutches = inefficiency and at full shift out the CVT system is already very inefficient. Belts sticking in the sheave can suck huge amounts of horsepower at higher belt speeds.I'm confused. I thought the more wrap, the higher the RPM? (Theoretically better speed as well? ) Especially curious as I just first tried mine at 2-3. Definitely warmer clutches than with stock (secondary spring) . Outside temp was 45 degrees though and no top end runs.
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
So with all this clutching talk, 3-1, 1-6, 2-3, 3-2. Which # applies to which component ? I know one is the helix and the other is the clutch itself. But is the first # listed ALWAYS for the clutch,or the helix ? Granted when dealing with a 6, its only on one component, but depending on who inserted the #s, as in 2-3 it could go either way. This might be causing some of the clutching problems. Consistant posting of spring wrap #s will help.Just received a pm from a member here and he tried 3-0 twist and had cool clutches, went 123mph gps with 8JP on a snow covered river....whereas the 2-3 twist, the clutches were a lot warmer and mph slowed to 117mph gps with both the 8JP and 8DN.
- 9K
- 7K
- 24K
- 33K
- 7K
