DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
.Just checked a couple things on mine....
Dalton B/O comes in at 14 pounds avg on fish scale(Backpressure) when set to 6/1(70) as per Dale.
The TP Orange set to 3/2(50) still had MORE backpressure, as It was much harder to install at 50 then above setup at 70.
I do realize twist "tangs" can be different from one to the next, so just something to consider.
I know in DOO world we go by scale rating, which does make for less confusion when comparing tangs/torsional values apples to apples.
As for compression, it seems to me just quickly comparing the two....the compression is similarly close from these two springs.
So I would think 50 as mentioned above by Shag and Terry would be the max to twist the orange TP to. Good call guys.
Dan
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Nice glad someone finally compared this TP orange spring.Just checked a couple things on mine....
Dan
No mention of helix angles or type of belt being used makes this all useless info tho. Run that spring with a 40 degree helix with an 8dn belt, you’ll probably want more twist than 40 degrees. On the other hand run that spring with a 33/35 and a Gates Carbon belt and you could turn it down to 20~30 degrees twist. Assuming untuned. M2C.
dem1000
- Feb 15, 2016
- Jokkmokk
- Sweden
- Side Winder MTX 153 -20
m8000 153 -19
Side Winder BTX 153 LE -17
M6000 153 -17
SR Viper MTX 153 -16 sold
Apex XTX -14 sold
Nytro XTX -11 sold
I drove today with 270r tp big venom with oranrge spring and 35 helix sat at 3 and 1 with gates carbon in powder snow and it worked well. Not as snappy as 3 and 3 though.
fourload
Dan , What do you think would the TPI orange spring be at 40degrees? I can't find my fish scale any more but that is how we did it years ago on the Srx's. Glad you did it so we could get a comparison.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Just remember I did not actually take a reading with TP orange as I had removed it a few days ago, and only just checked the reading on the Dalton. I just know by how much harder it was to put together.Dan , What do you think would the TPI orange spring be at 40degrees? I can't find my fish scale any more but that is how we did it years ago on the Srx's. Glad you did it so we could get a comparison.
If i take mine apart again sometime I will check it at diff degrees for comparison, cause as most of you know these fish scale deals are never same from one to another, and I only use mine to compare my own with same scale.
Dan
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
I never use a scale. Makes me feel fat!
swrtxlr
- Jun 29, 2016
- grantsburg
- 17 sidewinder rtx le
07 apex gt
00 srx olins
99 mountain max fully modded
gp 292
mod 292
Here's my update,after 600 miles with stock setup no belt issues. I installed TD Powertrial Dalton weights loaded to Ben's specs, thunder products orange secondary spring 100 miles hot clutches blew belt. Put stock secondary spring back in 400 trouble free miles warm clutches
Shagnos
So 700 miles when the belt blew? 400 miles on a new belt? Which belt? Which tune?Here's my update,after 600 miles with stock setup no belt issues. I installed TD Powertrial Dalton weights loaded to Ben's specs, thunder products orange secondary spring 100 miles hot clutches blew belt. Put stock secondary spring back in 400 trouble free miles warm clutches
Snowaddict
- Feb 28, 2005
- Menasha, WI
- '17 Sidewinder LTX-LE
- mstahl88
What was the TP orange secondary spring wrapped at?Here's my update,after 600 miles with stock setup no belt issues. I installed TD Powertrial Dalton weights loaded to Ben's specs, thunder products orange secondary spring 100 miles hot clutches blew belt. Put stock secondary spring back in 400 trouble free miles warm clutches
swrtxlr
- Jun 29, 2016
- grantsburg
07 apex gt
00 srx olins
gp 292
mod 292
700 when 8jp blew,400 miles on 8jp pt,CAI,turboforce canSo 700 miles when the belt blew? 400 miles on a new belt? Which belt? Which tune?
swrtxlr
- Jun 29, 2016
- grantsburg
07 apex gt
00 srx olins
gp 292
mod 292
swrtxlr
- Jun 29, 2016
- grantsburg
07 apex gt
00 srx olins
gp 292
mod 292
3-3
Snowaddict
- Feb 28, 2005
- Menasha, WI
- mstahl88
Did you ever try it at 2-3?
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
- 2017 Sidewinder BTX LE
2012 Nytro XTX 1.75
What helix are you running?Using Daltons up front.
You are correct that the 270R needs an aggressive normal - progressive helix.
Shagnos
Shhhhhhh...its a secret!What helix are you running?
