Firecatdude
- Dec 26, 2020
- NW Ontario
- 2017 ZR 9000 LTD
No that won't matter, do it the way I said, tighten slowly bringing it up little by little while rotating the track around and around, this will normalize the bearing on the shaft as the bearing self aligns and normalizes on the shaft without being crooked on the shaft.
Hey Knapp, is it better to turn the track by hand or use throttle when doing this? Thanks
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I see precision EFI has copied your design. That's pretty sad in my books... All the other big players sell yours from what I can see.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Yep just seen their copy on IG.....Travis should get some cash for his design!I see precision EFI has copied your design. That's pretty sad in my books... All the other big players sell yours from what I can see.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Travis's design can be installed on both driveshaft bearings if desired where as the copy can not.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I turn it by hand because you need to have the secondary off to access the wedge decent.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Disappointing to see. I know of some that made there own personal version and that doesn’t bother me, but for a vendor to copy and retail is pretty low.
Trying to figure out how you keep the china clone from spinning though if it is not snug initially in shaft?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
WE ALL know who gets credit for fixing the biggest flaw on these sleds!!!!! I wont forgetDisappointing to see. I know of some that made there own personal version and that doesn’t bother me, but for a vendor to copy and retail is pretty low.
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
Ok figured I'd share some photos. I have about 2000 mile snow on my '15 RTX-DX and hadn't serviced the driveshaft bearing yet. I didn't want to go much longer and risk wearing the drive shaft bad so decided to pull it apart, but didn't pull the rear suspension. I copied what another member on here had done with just loosening the track and jamming a sized length of wood between the driveshaft and the front cross shaft to hold position. Put on my contortionist hat on and managed to remove the 3 retaining bolts from inside the tunnel. Hard because of the setup Loctite on the threads.
Caught it in time, only polished a bit, no galling and no OD loss. The factory PEER bearing definitely was slipping on the shaft, and definitely had ingested some water. Slid right off the shaft, was indeed sloppy fit.
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
My local bearing dealer Greg at Buffalo Bearing had a choice of 6009 bearings, Cheap Chinese like the factory PEER which had hard almost plastic like seals, or a KBC brand that is a German company but manufactured in South Korea. Those had a nice rubber seal. The 6009 is industrial bearing with very general tolerances so you could have one tight and another loose.
Now for a snowmobile driveshaft bearing, super tight tolerances are actually a waste because of the environment it lives in. But in this application where you want it as tight to the shaft as possible I banked on the premise that the China bearing could be all over the place on the ID and the German company maybe tighter like their shaver razor blades... I was right, still slid over the shaft but no wobble.
I elected to remove the seals off the new bearing and flush all the factory grease out in my parts washer, then lightly repack with Amsoil waterproof grease.
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
Also had procured a Driveshaft Saver from Travis at BOP, I did put some waterproof grease on the tapers but also Never Seize on the threads, which I know will reduce torque required (threads lubes) but I was electing to try starting with light torques and increase to find where mine actually started to expand and grab the bearing.
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
The Driveshaft Saver was tight going into my 2015 shaft, I even sanded the ID of all the surface oxidation, Had to persuade it a little with a hammer.
Got it in place to recommended depth, slid just the new bearing on and snuck up on the torque starting at 10 ft lbs until the bearing no longer slid around on the shaft at 17 ft lbs. Backed it off and retightened 2X's to same torque and it repeated. Now I knew the minimum I had to get it to when it was all installed with the housing and I could no longer manually check it.
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
Started putting it all back together, Torqued to 20 ft lbs for a little more, the rotor still slid over the splines just fine.
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
Had to use a ratchet strap trick to draw the two running boards together to get the snap ring on the shaft . Seems good now. Will test drive it on the trails tomorrow.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Check it on a stand for wobble.. Turning the track while slowly increasing torques on the BOP wedge help seat the bearing better on the shaft(perKnapp).. Ask me how i KNOW?Had to use a ratchet strap trick to draw the two running boards together to get the snap ring on the shaft . Seems good now. Will test drive it on the trails tomorrow.
If the bearing is not seated correctly you will see the brake assembly wobble while turning track(10-25 MPH) on a stand. Don't ask me how I know!
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
Do you mean loosen the BOP wedge, spin the track up on a stand, to let the bearing settle, then torque it up? I was pretty sure the bearing was seated all the way in to the inner clip because before I reinstalled the outer half of the brake caliper and the brake pads on either side of the rotor, the rotor still had axial play on the shaft after I got the outer clip on. I don't think the rotor will cause the brake to wobble unless the drive shaft is no longer true. I don't think 20 ft lbs would deflect the shaft.
Was it the bearing possibly being cocked on the shaft causing the whole assembly it's in to wobble? Mine slid over the shaft pretty snug already so I will run it up when I tighten the track to check to see if it's cocked or the shaft isn't true.
- 6K
- 55K
- 36K
