hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Is there a year difference between the two?
Both 17 ltx. Also same color!
Bt04f250
- Mar 6, 2017
- IL
- 2018 sidewinder xtx 137 high Vis ordered 2012 Polaris rush pro r Le
Gotta love it!!Both 17 ltx. Also same color!
Any idea when they will be available for purchase? How about a price point?
TheMogulMogul
whupperofwhoops
- Sep 18, 2018
- Rochester NY
- 18 ZR 9000 RR
I really can't figure out, this plus oem epoxy style kit or just a new fangled kit that covers it all at once. I am in the position to do all it once now...
Bt04f250
- Mar 6, 2017
- IL
What do you mean by oem epoxy style kit? Did Yamaha come out with an update to protect this hose?
TheMogulMogul
whupperofwhoops
- Sep 18, 2018
- Rochester NY
- 18 ZR 9000 RR
No, most people are epoxied in already with oem kit and this BOP kit is an add.
Bt04f250
- Mar 6, 2017
- IL
Okay I’ve been waiting on this kit as I’ve already had my factory hose fail last season by a piece of ice. Just wanted to make sure Yamaha didn’t come out with an update or I was going to be bitching as they didn’t want to cover mine under warranty. I had to fight for partial warranty but if they came with an update that would be grounds for getting my money back as they are admitting there is an issue which they told me there is not lmao.
TheMogulMogul
whupperofwhoops
- Sep 18, 2018
- Rochester NY
- 18 ZR 9000 RR
No, this is just one of the latest thoughtful BOP reliability upgrades to keep you running...
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Why the need for two? Just wondering Trav....the PTO side rubber hose is above tunnel.
Dan
Dan
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Dan
The rubber hose is still exposed. Not as likely to get damaged, but figured if in there installing might as well do both sides.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Hey Travis,
Is F&S going to offer any "Barn-of-Parts" upgrade packages?
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Will that single bolt keep the bracket from pivoting and banging into the heat exchanger run
MS
MS
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Maybe my rtx is diff but mine is on top of tunnel.The rubber hose is still exposed. Not as likely to get damaged, but figured if in there installing might as well do both sides.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
From the underside though, there is still exposed hose. The edge of hose is still a snag point.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
MS
The protector is formed to fit snug around the cooler. Once it is installed it is locked in and can't pivot. The bolt is just securing it to the tunnel.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Thanks Travis....I agree, I got under mine and now able to get a closer look, just a small piece of rubber hose pokes down on left side.
I can see how tricky it is, as its a tough area to work in, even with skid out it would be tough to get a drill/rivet gun in there to install a rivet or two, It sure would make me feel better though with two attach points at least. It would be simple to put a nice large plate in there if the entire drive axle was out of sled, but I can not see people wanting to do all that work to install this.
I came up with approx 1.5" of space, from top of my 1.25" lug of track, to the bottom of stock coolant runner....I was worried about the lugs getting torn up by leading edge of this protector, but at this point we are darn close to the drivers, so It sure seems like it will be hard for track to slap upward that distance up there. So Im thinking it should be fine. Maybe deeper lug tracks not so much?
We were talking about this, and it seems the issue arose when these hoses were not being tightened enough(as mine was leaking from factory) and therefore allows ice to push the hose off/up the connection and allowing it to be torn or ruptured. If the hose is tight on the connections, it remains in place and is much tougher for ice. Sure seems like a poor design from the get-go though, should not have rubber hoses underneath a sled where just about anything can be ripping around in the tunnel.
Few pics I took today....
Dan
Left Side
- Poll
- 14K
- 11K
- 13K
- 70K
