Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
It sounds like he backed out the set screw, and likely market it with a small drill bit (maybe 1/8), then pulled the bearing off, and drilled it with the proper dia bit so the the set screw has something to bite and hold onto.
MS
			MS
		Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
I thought the same. Maybe even smaller than 1/8" but you run the risk of tearing up the threads, no?!?!It sounds like he backed out the set screw, and likely market it with a small drill bit (maybe 1/8), then pulled the bearing off, and drilled it with the proper dia bit so the the set screw has something to bite and hold onto.
MS
		STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Actually I just take the set screw out and stick the drill bit through the hole and drill a dimple in the shaft. Blue lock tite the screw in.
I have done 3 this way and have another to do when I get the chain case back together.
		Doc Harley
- Oct 17, 2016
- Here & there
Stain,Actually I just take the set screw out and stick the drill bit through the hole and drill a dimple in the shaft. Blue lock tite the screw in.
So you are setting the new bearing in caliper, installing brg on shaft, then just drill, add set screw (loctite) & rotate shaft to next?
Sorry, im no tech.
		STAIN
- Feb 29, 2004
- Vermont
- Vermont
Yes. The set screws are the last thing I do. I install the caliper/rotor and snap ring then drill all the dimples then tighten the screws in 2-3 passesStain,
Sorry, im no tech.
		Doc Harley
- Oct 17, 2016
- Here & there
Have bearing on hand & believe I'm on borrowed time.Yes. The set screws are the last thing I do. I install the caliper/rotor and snap ring then drill all the dimples then tighten the screws in 2-3 passes
Thanks, Stain
		STAIN
- Feb 29, 2004
- Vermont
- Vermont
They are easy to do. Cutting the shield off may be the biggest hassle.Have bearing on hand & believe I'm on borrowed time.
Thanks, Stain
You will see how much tighter they fit vs. the stock bearing.
Split the caliper when it is still bolted to the tunnel
		Doc Harley
- Oct 17, 2016
- Here & there
Will do....They are easy to do. Cutting the shield off may be the biggest hassle.
sailor joe
- Apr 4, 2019
- ma
- 2016 RS VENTURE TF
 2020 SIDEWINDER GT
Stain, do you own a repair shop? JoeActually I just take the set screw out and stick the drill bit through the hole and drill a dimple in the shaft. Blue lock tite the screw in.
White & Nerdy
- Feb 22, 2019
- WI
- 17 Sidewinder LTX, 12 Vector LTX, 01 SRX
I just cut the seal out and put the shield back in place. I figured I'd keep it for whatever little bit of strength it adds to the tunnel.They are easy to do. Cutting the shield off may be the biggest hassle.
		STAIN
- Feb 29, 2004
- Vermont
- Vermont
I have a garage, but do not own a business.Stain, do you own a repair shop? Joe
I just had a shaft done there this week, and now it's $160.
Seemed a little steep.
I may just opt for new shaft next time as my other guy is having some minor health issues.
stone88
Just an update on my shaft. I changed the track over yesterday and with 2420 miles on it the shaft and bearing still have the same tolerance between .002-.003 Must’ve got it right again finally can’t say the same for my 2021.
		hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
 2018 snoscoot
Been busy and have not been able to update.
I had an old worn 14 viper shaft and a brand new of the latest shaft tested.
The old shaft was 47 Rockwell C where bearing rides and 20 in the center where drivers sit
The new shaft was 61 Rockwell C where bearing rides and 27 in the center where drivers sit.
Both shafts were the same alloy steel.
Based on this info, the new 23 shafts are certainly harder. Have not done any research to see what the hardness of bearing races typically are. May just have one tested as well to compare against the new shaft.
- 70K
- 16K
- 10K
