lilrez
I was also running the non vented before. Ill let u know.What is your thoughts on stopping powwr vs. stock solid?
NYTurbo
I'd say the full is slightly better but I have no complaints . Still on original pads and they look good yet after 6000 miles on the original pads.
lilrez
What you mean full ?
NYTurbo
Stock one with no holes,
lilrez
Really .. U think its better than the oem vented.
Did u test em bac to bac
NYTurbo
I didn't test the OEM vented. Only the full non vented .Stock that came on my sled and the BDX light.
lilrez
Ah ok. Well it looks pretty if nothing else lol.
lilrez
lilrez
Byam
Locktight 635. Or 638 but you need to act faster
number1kyster
So, do we think the bearing is spinning on the shaft at all times? Or does it just start off under hard acceleration or hard braking?
I'll be checking mine soon. I'm on the fence about using bearing compound. I'd like to be able to get this bearing off someday.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
It rotates all the time that TRACK is moving.
geez150
Yes I agree, once you look this bearing in place with compound or other methods, how does one plan to remove it? It was a slip fit design for a reason. With compound is just a little heat required to soften it up so removal of the bearing can happen?
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
FIRE!
Turboflash
- Mar 18, 2019
- Southern MN
Yes, apply some heat inside end of track shaft (it's hollow). That will soften loctite. Some build a puller that uses the same 3 bolt holes that hold the casting piece to the tunnel. Either way, it's not that hard to get off. I'd rather put up with having to get it off than having the track shaft destroyed and/or the brake rotor too.
- 6K
- 58K
