What about knurling it if possible?
craigwsrx
- Feb 19, 2007
- Fenton Mi.
- 2017 Sidewinder 27,000 miles
2009 Nytro xtx 31,000 miles
2006 Attak 26,500 miles
2003 RX1 13,500 miles
2000 Mountain Max 14,000 miles
1998 SRX Mountain 17,000 miles
1995 V Max 600
1979 SRX 440
1975 GPX 338
1973 GP 338
I tried knurling on one of my shafts but drive axle is still softer than bearing so it ate the knurling up and then went on and ate axle.
Fast
- Sep 25, 2018
Hows the green lock tight holding out?I tried knurling on one of my shafts but drive axle is still softer than bearing so it ate the knurling up and then went on and ate axle.
as long as the bearing race dose not slip against the rotor/anchor, the bearing would seize in place over time.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Met with one of my machine shops today and he’s making up another prototype option for me.
Would prefer to have a fix that requires no mods to shaft or brake rotor!
Stay tuned.
Of topic...but also maybe some billet gas caps for next season too!
Stay tuned.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I am in the middle of doing my off season maintenance and plan to drill and tap to add a set screw to lock the inner race
I read somewhere that someone did this and it worked well!
The hole In the center of the shaft is deep enough to reach where the bearing sit!
I will post if I am successful
I had to bend an allan wrench as it was difficult to get a 1/6 turn. So when I tighten I switch back and forth from the bent allan wrench to a straight one. Another option would be to use a very short hex head bolt instead of an allan bolt, then the twelve point box end of a wrench would work.I am in the middle of doing my off season maintenance and plan to drill and tap to add a set screw to lock the inner race
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Tuned!Met with one of my machine shops today and he’s making up another prototype option for me.
Stay tuned.
IH8CROWS
Where did the pic go.I use this tool. You can buy the whole kit from parts stores or even Home Depot/Lowes for short money
A lot of your pics have disappeared eleswhere also.
vx700xtc
How bout welding a threaded insert in the end of drive shaft. Then machining a collar that would fit over shaft and push on brake rotor.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
No issue welding if have access to a welder. I am seeking bolt on solution easy for anyone to install.
Yes I did. Why did they disappear?
It might have Ben a google search images and links change. Best to upload or open image link and insert as image link.
MarkAttack
Stay tuned.
Prick punch the shaft then use Green Locktite brand bearing mount.. I have done it many times on Heavy Duty Truck wheel bearings Transfer case housings.. ect..
MarkAttack
Lots of Prick punches then Green Locktite bearing mountWhat about knurling it if possible?
- 6K
- 55K
- 36K
